TOPIC: 71 short shaft 800
71 short shaft 800 1 year 3 months ago #147616
  • Fatlenny
  • Fatlenny's Avatar Topic Author
  • Thank you received: 17
At one point last year I picked up a 800 merc with plans on using it for my current project. It needs more than a few wires replaced on the power head. Found another motor for the current project and set this one aside for the time being, have a project in mind for the near future. It turned out to be a 1971 800 short shaft with an extension kit to make it a long shaft. I had read somewhere than anything above 50 hp in a short shaft is rare. Is this true, do I have something special for a smaller HP motor?
71 short shaft 800 1 year 3 months ago #147617
  • Thank you received: 114
They're quite desirable if one is repowering a classic boat with a 15" transom. Especially if that boat is a high-performance model that you'd naturally be raising-up the motor for better speed. (usually coupled with a high-performance prop). Obviously a short shaft already has a 5" leg-up in that respect, and will have a lower center of gravity on the transom than a longshaft engine (say, used with a jackplate to raise the motor) would.
Another consideration is that you don't need to build up the transom of a S/S boat to fit a more readily available longshaft motor.
The following user(s) said Thank You: Fatlenny
71 short shaft 800 1 year 3 months ago #147619
AND,...That short shaft driveshaft housing assembly (DSH) can be used under a 650ss, 950ss, 1000ss, 1100ss, 1250, 1250ss, first edition 1150 & the 1350,...If your 800 4 cyl is too puny for the boat of choice. The exhaust extension plate (EEP) from the 800 will only work under the early 1150 & 1350 (maybe the 1250???), but armed with their respective original EEP from each listed model, that first edition 800 DSH, swivel housing, and transom clamps, etc can bring you closer to a variety of 15" shorty options.
The related originally long shaft exhaust tubes on these specific Mercs can be easily shortened to a short shaft application.
Some of the power head mounting studs may need to be swapped out to match the lengths required by the 800 DSH, so hang onto those original studs, if doing a power head swap.
You might find that you need to leave out/remove the (2) 5/16" studs at the aft of the power head on the (10) stud units, but the power head, gasket & DSH won't care.
The shorty 800 lower unit is originally a 2.31:1 ratio, where the bigger inline-6 used a 2:1, and the 1350 used a 1.78:1 ratio, so if you only have the long shaft lower unit for the power head of your choice, I would disassembly and ship out that driveshaft to be shortened to use in the 15" application. That way you can re-assembly your lower unit without needing to re-shim or re-set lash, etc.
Trivia for the day :-)
doc
The following user(s) said Thank You: VinTin, Fatlenny
Time to create page: 0.152 seconds
Aquabird steering wheel
( / Parts / Miscellaneous)
05-28-2024
1958 Performer Havoc 14 ft
05-24-2024
We have 5323 guests and no members online
